1988 Rogue 2420
bit of work on Sunday....
Garmin Mounted...... had to make a wood puck and cover it with vinyl
side bolsters being installed...... need to get a new mandrel for my riv-nut tool for the #10 screws. just the christmas trees right now
Admiral said she didnt like the EVA...... so seat boxes are mounted
a bit of fine-tuning on the side bolsters on Saturday. measure twice, cut once..... then when it finally gets installed, needed to trim the return on the top slightly. the thickness of the vinyl shifted the panel aft about 3/32
first removing staples I just installed a few weeks ago.
Also mixed up some paint. I had some parts painted at work with Imron. wanted to match that color with Rusoleum because I do not have the money left for a $750/gallon bucket of paint.
first, the color is called "stardust" its a smoke-grey metallic with a hint of blue
So, pick up 2 quarts of metalic aluminum, 1 quart of black and one quart of royal blue
into the can go the two quarts of aluminum. then I was sneeking up on the color. first 600ml of black and 240ml of the royal blue. the color looked correct until it dried. final mix prior to shooting turned out to be 2 qts aluminum, 1 qt black and 1 qt royal blue
Sunday was scuffing, masking, and then spraying the outdrive pieces
I have discovered that I am currently looking for at least 5 small pieces of the outdrive that have been misplaced over the past 2 years......
here is the plan for this weekend
I am hoping to be assembling the outdrive Satureday
also plan for Saturday
wire trim pump controls ~ 1 hour
wire bennett trim switches ~ 1 hour
install controls ~ 1 hour
Hoping to get to
Fix folding seat bottom ~ 2 hours
make new aft seat back frame ~ 3 hours
make new aft seat bases ~ 1/2 hour
make dock light covers ~ 1/2 hour
things I can use help with on Sunday
Wire Garmin - have backbone kit ~ 1 hour
wire VHF antenna ~ 1/2 hour
mount VHF mic mount ~ 1/4 hour
wire amp ~ 1 hour
swap out radio remote ~ 1/4 hour
wire all-around light ~ 1/4 hour
zip tie wiring ~ 1/2 hour
install chain link on bow anchor line ~ 5 minutes
install side kick panels (requires drilling a few holes) ~ 1/2 hour
install aft side bolsters (requires installing riv-nuts) ~ 1/2 hour
Install wing window seals (cut and fit) ~ 1 hour
install wing window latches ~ 1/4 hour
adjust bimini - making new front stanchions have everything ~ 1/2 hour
make radar arch brace for traveling while down ~ 1/2 hour
welllll
a 1/2 hour job is one broken fastener from a 3 hour ordeal.
this weekend
kick panels done
one side bolster in
new stanchions made for the bimini
wired the bennett trim tabs
wired the controls
still need to finish wiring the tilt/trim gauge
spent 6 hours pulling stuff out of the cabin and cleaning it
glued in the pivot bushing into the outdrive fork
Monday evening was spent making phenolic shims and re-assembling the reverse latch assembly
little progress this weekend. spent most of Saturday getting mulch and stuff for the house
installed the mid-section on the outdrive. the Sierra kits didnt have all the o-rings. Sooo..... pull out my o-ring kits
The area at the bottom of the cabin is an empty chamber. I may make a stainless lockable locker and simply cut-off the 6" of rot.
did some more wiring to finish the trim gauge...... only to find all I get from the trim system is a "click" of the relays. need to look at the circuit breaker feeding the trim pump
did some measuring of the cabin area. need to formulate a plan tonight.
alldodge
A well know member would/has said this
check the connections at the pump wiring
make sure they are good and clean and tight
should be ATF or 30 weight in the trim system. check your drive manual.
troubleshooting guide in the manual as well (last section)
I know..... I also replaced the permanent fuse at the starter to a remote mounted circuit breaker with a manual reset. I never checked to see if the reset was pressed or there is voltage on the other side of the CB. I will pull off the engine cover and crawl in the bilge tonight
Thinking the CB was flakey.
Wiggled the manual reset because it wasnt tripped..... However, trim/tilt pump works now.
mickyryan
yep its sad but folks are out filling boats with people instead of just fishing and whatnot ...
i always boat to get away from people so its not computing in my mind why anyone goes to those islands and stuff
so here are some of the updates from Sunday and Monday....... spent Friday night watching the neighbor burn down his shed....... someone called the fire department (wasnt me)
Saturday was staining our fence
Sunday was finishing the fence staining. Sunday night was working on the seat bases
measure twice...... cut once..... more on that later
come back Monday, realize I phuckedupski the seat base
0330201808_resized.jpg ....... So
time to repair
cut some 1/4" fillers, re-rabbit the phuckupski,
re-do the rabbits
