1988 Rogue 2420
Sit right there and we will tell you a tale.....a tale of a fateful trip PXL_20221016_183725182.jpgPXL_20221016_183725182.jpg
A few boats on shore on the Manatee River
#$@&! Wasps built nests in the boat again.
Got a new filter/spark arrestor for the rogue. Next week to recaulk the rub rails
The more we use the boat, the more things we find need work
Hour meter quit sometime this year, courtesy lights quit working, NMEA gateway for fuel level quit working.
Replaced anti-siphon.
Need to redo the headliner and finish the closet and shelves
tpenfield
Scott . . . That is why we have winter in the northern areas. so, we can catch up on all of the maintenance and repairs :ROFLMAO:
Yesterdays's celebration of another successful celestial star orbit netted a 13 gallon fresh water tank and a transom swim shower.... will go hand in hand with the pump, fill, and a few other bits squirreled away in my parts bins
will break away a bit to work on the boat.
Bittersweet..... Lost my good friend Jeff to cancer a few weeks ago. His widow offered some boat stuff.
Two ditch bags, wet suit, air horns, Bennett repair kits, dock lines, ski ropes, dock step, spare anchor, small fuel tank
This was skin cancer that metastasized. I do not wish that on anyone
Haven't used the boat for a while .... Rain ever weekend, then hurricanes. Spent a few hours scrubbing Salt Shaker.
Next weekend, have to clean the cabin as lizards, Frigs, and humidity did their best to trash the boat
The 3M 4200 is failing again on the run rail. A write up coming
Ok, so after removing insect and amphibians from the boat, loading up everyone.......the channels are gone from the hurricanes...... The water is too skinny to making it from the launch to deeper water unless the tide is in.
I should have swapped props, as 10 people in the boat made it a pig trying to get out of the hole.....
Ran out of deep channel and buried the drive in the mud
Knowing a tow would be hours. Decided to jump in and push. Got it 300 yard to water deep enough to lower the drive..... Came back without cooling water
Will look at that after the 26th
Ahh Christmas memories
tpenfield
Water deeper than 2 ft would help more
Yup . . . My boats have always been moored in a shallow area . . . I was constantly picking up sea weed and it would clog the cooling system.
Sea water strainers did the trick.
Lou C
The guy at the local marina who drops my mooring tries to locate it so that I'm in at least 5 feet of water at low tide. If it's 5 at low it's 11-12' at high....
Now where my brother keeps his boat, it's like 2.5' at low, I advised him to try to get out about 3 hrs before high tide and return not more than 3 hrs after....
