- Oct 25, 2011
- 25,248
Re: Where Do I Begin? - 1988 Sea Ray Seville Deck & Stringers
Welcome back. Ernie looks like he had NO Problems adjusting to his new home! Congrats!
So you say he's a service dog? Can he run a grinder? Help PL the stringers? All supervision probably, no actual work.....:facepalm:
PL may still be a tad soft at 48hrs, but check a couple times leading up to the 48 mark. You don't want it off gassing behind the PB & the glass layups. Then it's PB fillets, CSM, then 1708 & repeat: CSM, then 1708. If you are capping the stringers after, all 4 layers can be done wet on wet, even on the PB. It will go may be easier to let a layer tack over before laying up the next, but no need to wait for the layer to fully kick. But read through Don S's helpful tips thread & oop's index, they should both go over the wet on wet layups. I think it's even better when you do them wet on wet. Bonds as a unit instead of layers, or something like that, heat buildup as they cure is something to watch too.
BTW, what was up w/ logging in?
