Re: 1988 Sylvan Offshore 22'
Beware the rivets ! I had a freak mishap with my 18' starcraft, while loading it on the trailer I got hit by a blast of wind ,and a big wave at the same time. It slammed the boat down onto the bracket holding one of the rollers. Not the haul it was protected by the rubber roller, but the very tip of the bracket fit ONE! rivet just right and pop!! no more rivet. We tried to find someone that knew how to replace it, we went to boat dealers and repair shops. They basically all said just use standard rivet with some sealer ( it's only one rivet ). Long story short found one of my dads friend knew all about rivets, where to get them and how to install them. That's when I learned the of structural water tight V.S. Pop rivets. If the rivets they used, are the same as the haul then it is for stress loads, so as to not leak. Just saying beware. Do your homework on those before you remove them.
