1988 wellcraft bowrider to cuddy" conversion (Splashed)
mickyryan
No Title
what I did this weekend :)
gm280
Nice trailer work there I'd say. Keep posting your project. I am certainly interested in it. :thumb: :thumb:
mickyryan
thanks pusher its cream and red to match boat it was galvanized so it isn't pretty up close but its coated and should last me awhile :) there were runs thought they were mine then realized it was the galvanizing lol made my light poles and working on lights tonight
mickyryan
No Title
OH MAH GAWD IM SO EXCITED SHE IS BACK ON THE TRAILER !!
anyways tomorrow I splash her to get a idea how she sits and to mark waterline... stay tuned if she sinks we will has video of that as well :)
mickyryan
It floats nice :)
sphelps
You should stay good and dry in that one ! Looks nice !
How did you mark the waterline ? Go for a swim ?
mickyryan
Didnt half to because water came perfect to inner chine end on bow and original line on rear low side so i figure ill use that and put a 2 " black line between red and white for varience ?
mickyryan
Still cant believe how close it is to otiginal waterline of boat ill post a pic of that shortly and sude by side comparison
gm280
I always said, it is better to be lucky then good....but that is only for me, not you. You seem to know what you are doing. Can't truly say the same for myself. :facepalm:
Pusher
That looks great! Looks like she leveled out nicely. I bet you can't wait to take her for a spin.
mickyryan
many nights of staring and calculating with shoes off to make sure I didn't have mud in my eye and crow on my breath, but in the end I was still shaky as hell till I saw it lift off the trailer,Since this my first time doing this lol.
Sad part is I found out I have a 3 " slice in my hull I never noticed because it was under a brace so as I was sitting there I started seeing water like a hour into float test and couldn't figure out where it was coming from, pulled the boat and bam we found it ,
I was kinda relieved because it don't appear my transom was leaking it was coming from this that I know can be easily fixed, must have came like that and again I just never saw it because I never had to do anything to bottom of boat yet ! pic as soon as camera gets charged . also need advice on fixing , cant get to it inside it isn't even visible its in the outer layer of hull inner layer is just fine.
Pusher
You might be able to open up the crack to an 1/8" and sand the outer layer down. Before you lay a patch over the 1/8" crack you could inject PB into the hull with a syringe and load it up. Then lay the patch on the outside and fair everything smooth. I'm sure there's a better way to do it but that might work.
I'm glad it's not the transom. These things keep the dream going as my brother says.
mickyryan
yeah I have a syringe that I can inject pb with that was what I was thinking then leave a divit for gelcoat its small so I think it will be a easy fix , just not sure how it got there or where it came from, its not on chine just slightly in from it so pfft!
kcassells
Well if thats the worst of it I'd say you had a great time with the float! You can open up the crack, clean it up, have a wet out pc. of glass ready lay on crack and as it's setting up push up into the void and let set. Come back with some pb after it dries, sand out and then layer your new patches.
mickyryan
welp I got it running today for around a hour man those lifets were sticky at first, 8 yrs and just a couple of turn overs and she purred after awhile, got scared I couldn't find oil on dipstick so added more and where ever it was hiding it returned so now I need to drain a bit , getting massive blow by hoping that settles dowjn but if not a rebuild is in store in future
she does idle at 700 just fine don't smoke and don't overheat
http://vid1184.photobucket.com/album...820_121325.mp4
http://vid1184.photobucket.com/album...820_122546.mp4
http://s1184.photobucket.com/user/Sinzz/media/boat/20160820_122546.mp4.html
