1989, 100 hp Mariner
utfyrfytr
Last fall my 89, 100hp Mariner would not run at WOT. Coming back across the lake it started slowing down and would only run at 1/2 throttle or less. There was no missing or rough running and it idled fine just wouldn't run wide open. I was going to take to my mechanic only to find he has moved 90 miles away. Not many other mechanics work on these older engines around here. Thanks for any ideas you may have.
Water pump maintained , yes or no ? ----Do a compression test and post your numbers.-----Check spark to see if it jumps a gap of 3/8" on all leads.-----Oil injection system in service ?-------Oil pump output checked ?----Is the oil pump turning ?----Fuel checked for water ?-----Any other history on this motor ?
