1989 110 Hp. Evinrude, Bogs Out At Full Throttle
BIG-D
1989 110 HP. PRO SERIES EVINRUDE. ON A 24' SUNTRACKER PARTY BARGE DL-24
WHEN I GO TO FULL THROTTLE IT TRIES TO QUIT, BUT IF I CHOKE IT IT WILL GO BACK UP TO FULL THROTTLE. AFTER CHOKING THREE OR FOUR TIMES. RUNS GREAT. IF I LET OFF THE THROTTLE AND TRY TO SPEED BACK UP. HAVE TO CHOKE AGAIN. RUNS GREAT AT IDLE. HAVE CHANGED PLUGS. BUT STILL WON'T RUN AT FULL THROTTLE WITH OUT CHOKING. HAVE CHECKED GAS, GAS LINES, FILTERS. DON'T KNOW WHERE TO GO NEXT.
THANKS IN ADVANCE FOR ANY HELP.:confused:
tashasdaddy
Re: 1989 110 Hp. Evinrude, Bogs Out At Full Throttle
fuel starvation, clogged high speed jets, most likely. also you have a primer not a choke.
Primer Solenoid
the primer replaced the old choke butterflies in the carborators, pushing in the key activates it, like the old choke plates, but injects fuel directly into the intake.
The red handle is used when your battery is dead, and you have to rope start. You move the handle 180 degrees.
Normal operating position is with the handle back over the body of the solenoid, like in the picture below.
