1989 25 hp airflow
norman2013
Hey guys, I just purchased a 1989 johnson 25 hp motor model number j25elceb. I purchased it for dirt cheep and when the temp is 50 and above it runs great. But when it is below 50 into the 20s, it starts up great but dies out after 5-10 seconds. It looks to me that it is missing the airflow intake thing at the front of the carb. I will post a few pictures of it on this post. Please let me know if this air intake is needed for my motor to run in the cold. I was thinking about making a little plate that fits it perfectly to cover the carb end up and start with one hole drilled into it and drill more until proper airflow?:confused:
-- another thing when i was trying to get it to run fine in the cold, all i did was cover up the carb end with my hand and it ran fine.
Bosunsmate
Re: 1989 25 hp airflow
You could check that the thermostat isnt stuck open. The air intake shouldnt affect it that much
jasper60103
I have basically the same motor. There's no air silencer on that model.
the motor is cold, use more choke and throttle until it warms up
boobie
Yes........As said above, use more choke when it's cold.
bonzoscott
I think that model has an electric primer instead of a choke. You may want to look towards that as your problem.
guys, its a dumb motor with a simple carb.
EFI has spoiled the world and people forget how to run dumb small engines. if it runs right above 50 degrees, then there is NOTHING wrong with the motor. for when its cold, it needs more revs and more fuel just like your EFI motor does automatically in your car. normally its called a choke. call it an electric primer, it does the same thing. it richens the fuel mixture to about 10:1 for when the motor is cold. once the motor is warm, run it as normal.
So this is normal?
All the carb engines I've had have been quite cold-blooded when the temperature drops. Learn to give it a shot of primer as it starts to die to keep it running, coupled with idling for a little while with bit of throttle until it warms up.
norman2013
Ok, Thanks guys! I will give all of your suggestions a go around! Thanks
F_R
You may have to experiment with different idle airflow orifices. Or at least try giving the idle mixture needle a tweak. Can't say that I have much experience with boating in temps in the 40's.
