I'm changing the impeller on a 1989 5hp long shaft, I've done short shaft impellers a few times, but this long shaft has an extra 5" extension housing that is attached at the front and I can't remove it from the lower unit. The manual says nothing about this 5" extension. According to the part diagram the rod that holds it in place is not threaded and should slide right off, but it isn't budging. The rod that holds it is the same one that holds the short shaft in the front. Except it is 5" longer. Anyone ever work on one of these long shafts?
