1989-90 bayliner 2159 hardtop.
mickyryan
today , waiting for that rain from storm here in fla, i cleaned up my work area since cant touch boat for a few till it cures
sphelps
Yep pretty nasty up here too Mick .. Looks like a little break in the rain this morning for a bit . I think I may go catch a few waves before the beach gets crowded . More showers later today .
i like the looks of the Rapter stuff . May try it on the Manatee deck ..
mickyryan
Today im Building the Hatch covers for the back of the boat , not fun but i got to get it done :) will be last bit of glasswork for awhile :)
The rebuilding Phase starts soon , excited about that, i will do top cap completely before bring the hull back to mate them , easier getting in and out with it on the ground:)
mickyryan
ok so came up with a few ideas on making the hatch covers, my final approach was to cover bottoms of lids grind out for the lip of the hatch
i used coosa hollow core sandwiched 2 pieces together with 1708 between them then coated with csm on top
then i pva the hull and made peanut butter ,
filled it then layed my hatch down smearing out excess, now i have hatches that are good to go and lightweight just need to sand them down a bit so there is a loose fit in the holes and move forward. i did take some pics but i felt it was much better explaining because pics wound up too blurry.
as for pb i used the minimum mekp to keep heat down and did it at night to keep temps as low as i could to keep it from overheating.
mixed [h=3]Diatomaceous earth "microscopic broken glass skeletons "and chopped fiberglass with de a good respirator is a must when sanding on it!.[/h] my mix was 64 oz of d e " it isn't actually 64 oz its just i used liquid measuring cups to scoop so using a 32 oz mixing cup i filled to the 32 oz line unpacked and sprinkled in after i had catalyzed the resin with 18 cc mekp it was 64 oz of unwaxed resin.
used about 16 oz of chopped fibers again not true weight measurement but using line just for measuring.
the last scoop of de i used to find a consistency i liked and stopped so might be some extra left in cup for your taste in smoothness.
kcassells
Mick,
Put up some pics on the hatch, I would like to see them. Thinking about building some of my own.
And is your boat self bailing?
mickyryan
yeah boat is self bailing got a pic or 2 of where i am thus far these are the Rough plugs , now just need to sand and give them some room and i am making these to open with a piano hinge not like originals that were just pull up and stuff.
mickyryan
I will flip them and get pics for ya of bottom once i have them in line, I should have done this before i painted but i am using pva so should be ok. biggest thing is using minimum amount of mekp to keep the thick stuff from cracking.
mickyryan
cant do much on the hatches until they cure out , so i am working on windows , found the track inserts just need to decide to keep them grey or paint black , i kinda like the black frames better, also trying to find drip edge aluminum for the top but haven't had much luck.
mickyryan
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ found it! http://www.restorationstuff.com/featured8.html
mickyryan
i have been waiting to pull the hatch covers so they didn't distort ill have more pics up this weekend:)
mickyryan
got window tracks back on and windows tinted , i hate butyl lol took forever to clean off, it had melted and ran down windows in some places , so going to go with a alternative when replacing the windows back in
mickyryan
original, just cleaned sanded etched and repainted with urethane single stage looking to purchase the track inserts and will have like new sliders on the sides:)
