1989-90 force 150 carb kit
lucas70458
anyone happen to know what carb kit i need? price ranges from 11.99 to 25.99 not sure how to tell what one i need.
roscoe
Re: 1989-90 force 150 carb kit
Mercury part number 820576A 1 no longer available, but DougRussell.com still has some. $125
Still available at boats.net , but they have a way of not having what they say they have, and taking months to deliver ($65)
Not aware of any aftermarket kits that fit
jerryjerry05
Take your carbs apart and see if you really need them.I have found that the kits don't fit anyway.Unless you have water in them they will be salvagable.J
lucas70458
cleaned out the carbs they were not to bad after all... i was checking the charging system if the magnets are cracked in the flywheel will that cause a problem?
roscoe
cracked, broken, may cause troubles. Missing magnets will definitely cause problems.
