1989 Evinrude 88hp zerk grease fitting locations midsection
appleo
Anyone have a diagram showing zerk fittings on the midsection?
EG the shaft sleeve which the motor midsection pivots left or right when steering?
My steering cable is fine and i have lubed the outboard tube in which it clamped
Now Looking for zerk fittings for that vertical portion
thx
Tilt the motor all the way up.----Then look for a lube fitting for the pivot assembly.
appleo
Already did. saw no zerk. maybe it broke off. hence the request for assistance
i'm pretty sure, like the v4 and v6 motors, you need to move the motor lock lever to the lock/trailer position to expose the fitting on the port side
Grease fittings are in plain view on the port side of the swivel bracket.----Found them on several midsections.
Sorry----No peektures from me.----Come over I show you where to take one out to take home.
