northwoodslivin
- Feb 3, 2010
- 323
Re: 1989 Johnson 20HP
Hey Guys,
WELL I finally got around to testing the new water pump I installed "success" She pisses like me drinkin beer
Problem though, she runs, but I dont know how to describe it "first off, could someone that knows tell me that when the motor is running do I need to pull out the primer at all? the description on the label confuses me"
I dont know how to describe it but its almost like it runs off and on on one cylinder some times. If I put it in gear and give it a bit of throttle or increase the low speed setting it will idle but I am not sure if it is 100%. I just ran a bit of decarbing stuff through it hoping that would help, then ran it out of the motor 10 or so minutes later and relplaced the plugs, same deal. So I sprayed the remaining 2/3rds of the can through the carb giving it throttle in forward and shut it down and I am going to let it sit a good 15 minutes "almost that time now"
I made sure the gap was correct and pushed on all the plugs and what not to make sure they we're tight. Other then that she runs good, I let the motor run for a good 15 minutes. Will do so now, will report back, in the mean time if anyone has any suggestions?
PS plugs and coils look like new!
Hey Guys,
