1989 mercury scared piston
reynold460
hi guys i have a 1989 115 hp four cylinder outboard serial number oc106992 that i had out last weekend and scared the # 2 piston. going to tear motor down to fix but am wondering what caused this to happen to begin with, when i took off the exhaust cover all the cylinders had visable signs of oil but the one that is scared , so i belive the oil pump was working , is it possible that the needle valve stuck on the # 2 cylinder and ran it dry , the motor was running fine when this happened although it wasnt idling to good possibly because it only runs on two cylinders at idle but only one was firing , pulled the sparkplugs out and the top 2 are grayish brown and the bottom two look fine compression is 130 on all cylinders but # two which is 0 here are the pictures what do you guys think i should look for to fix this http://s1252.photobucket.com/albums/hh571/reynold460
Faztbullet
Re: 1989 mercury scared piston
The carb ran lean or preignition from ignition problem, cant really tell till ya get it disassembled....
reynold460
did you look at the pictures the top two plugs are a grayish brown color
