1989 vs 2008 4.3 differences
1987sylvanoffshore
What exactly is different between the 2 engines (just the bolt on stuff) ?
More specifically are the power steering and alternator brackets the exact same or different from the older motors 1989 vs 2008? Flywheel the same size? I’m purchasing a 2008 and want to see it those items mentioned can be swapped from my old engine of if I’m going to be looking for new ones. Thanks
matt167
4.3 has many fairly major differences between those years.. Just going from 1989 to 1993 there were some fairly major improvements..
I think even the intake manifold is different. I know it would be on a 5.7L for sure, which is a Vortec head vs pre vortec difference
Scott06
nola mike
Most things will swap over with varying degrees of difficulty. You'll need to swap the balancer, you'll need new water pump and new intake manifold, a bunch of metric nuts and bolts. I thought the flywheel would swap, but I used the one from my donor. Alt, ps, tstat, exhaust straight bolt on.
Check my swap thread for more heartache:
MichaelBC
Hello,
I am just about to finish such a swap.
My original engine is from 1993, so no Vortec heads. The new engine is just factory new with Vortec heads, balancer shaft and roller rocker arms.
So I can tell you the difference between new and 1993.
Balancer - same
Flywheel - same
Flywheel cover same
Exhaust manifold - same
Starter - same
Oil dipstik is different but old one could be used
Old circulating water pump does not fit on the new engine
Intake manifold does not fit. The old one has less bolts
The new one has this serpentine belt and the alternator on the other side when it is built by facory. But all the holes and threads to mount the brackets the old way are there. THe only issue is that GM seems to have randomly mixed metric and imperial threads. So the flywheel cover, engine mounts and starter are metric. The water pump is imperial.
So what needs to come new is only the water pump.
Old water pump is in the back
So the flange with 3 holes does not fit here on the new engine.
The old engine looks different
New oil dipstick with drain hose
Old version
The new dipstick hose is much to high and I will have to cut it and also the dipstick so I can close my engine cover.
The new engine also has a coolant drain thread only on starboard side. the one new to the oil filter is missing. The old engine had one on both sides.
Scott06
Yeah the mixed US and Metric sizes is pretty funny, not sure why GM did that as the US size 3/8" x16 is so close in size to the M10 on the metric blocks.
Usually the block casting number will have an M in it like mine was a 090M for metric.
nola mike
That freakin killed me when I did mine. Couldn't figure out why my bolts were stripping out when I torqued them down. Sometimes. And you shouldn't need to cut the dipstick, just the tube.
Scott06
When you yank the 4.3 and put in a 5.7 the bolts will all be us sized so no worries...
MichaelBC
If I cut the tube only then my dipstick will go in to deep. So from my understanding I will need to cut of the the same length of the dipstick as I cut of the tube, so the end of the stick is on the same level again.
nola mike
At least on mine, the dipstick was shorter than the tube already and didn't need to be cut. The tube extends to the bottom of the oil pan on the marine engine so you can suck out the oil. If you cut the tube you'll need to access the drain plug to change the oil (I don't think a hose through the dipstick tube will make it to the bottom of the pan). I used an oil drain hose that I can pull through the bilge hole.
Scott06
Maybe take a tubing bender and bend it to the side so you can keep the hose connection for sucking oil??
Lou C
Hello,
Balancer - same
Flywheel - same
Flywheel cover same
Starter - same
Old version
this concerns me because I question how the port side of the block could fully drain without a drain on that side. There is a boss machined there that on some engines you might find a knock sensor screwed in and that might have to be removed to drain it. I'd look closer and would be really surprised if there is not a drilled hole there, maybe filled with a square or allen plug?
PS with a nice new engine like that all clean on the inside I'd install a closed cooling system, it will make the engine last 2x as long if you boat in brackish/salt water and make it easier to winterize as well.
nola mike
Bend what to the side? There's a baffle in the pan preventing anything from reaching the bottom. Merc uses a whole different tube assembly on the newer engines. Although I guess I'm not sure if the new pan started with the vortec heads or earlier
MichaelBC
There are three reasons why I do not care too much about the thread on the top to suck oil out.
- I do not own such a pump
- The dipstick tube is combined with an oil drain hose that can be pushed through the bilge hole
- My oil pump has a thin long hose than can be pushed through the dipstick tube to the bottom of the oil pan.
If I cut the tube only then the dipstick will go too far in.
MichaelBC
Well, maybe my wording was wrong. The old engine had this shitty blue plastic plugs on both sides like you can see here.
I call them shitty because on two of them the top just fell off already and cooling water was running into the bilge. If they were solid instead of hollow inside then the damage would not be that much. So I filled the little holes with expoxy resin on the new ones.
The new engine has one bolt on starboard side.....
.... but no thread like this on port side.
Maybe if you would remove the big plug near the oil filter, that would drain the engine.
I am also not too worried about this as I did buy a closed colling system already for the old engine and will swap that to the new one. So there is no need to drain the engine for the next couple of years as I am running it with anti freeze for rust protection and during winter my boat is in a heated garage hall.
nola mike
My mistake,I thought you were bringing the old oil tube over. You already have the correct one on there. Yes, like Scott said bending the tube if possible would be the cleaner solution, but cutting both should be ok as well. Obviously you'd need to scribe some new marks on the bottom of the dipstick. That hole on the port side certainly looks like a drain, but like you said it's probably a moot point with the closed cooling. Still might be worth verifying while the engines out though
Lou C
Yep that recessed hex head plug is the drain. Knew it had to be there! Good you have closed cooling already.
MichaelBC
As it is easier to do as long as the engine is outside the boat, I decided to cut the hose today.
I found the mark hard to see already on the old dipstick and so I cut some gaps into it which made it much easier for me to see the level area.
So I will just do that on the new one too.
I cut of about 11 cm.
Then I used the cut off hose as a measuer for the stick, plus the thickness of the cutting disc.
Cut it, twist the edge, cut the marks ... done.
MichaelBC
Today I found another thing that can not be swapped.
The brackets of the electrical connector and the oil monitor were fixed with the bolts of the intake manifold. The distance of the holes does not match the Vortec bolts distance. So will think of a different place where to mount this. Both do not neccessarily need to be mounted to the engine.
some light reading. however I would have suggested swapping the entire bobtail
