Faztbullet
- Mar 2, 2008
- 15,934
Oiling is way different on 4 stoke car HiPerf vs 2 stroke..I will see if I dig out a old coated piston
Yea well seems it’s useless like you said on the boat motors and not like automotive as I called them.Teflon coating only for break-in ...its gone in about 3 hours running. just about every puts the black coating on
Any chance you know factory specs for max clearance on the piston to wall? But yes your correct on the Teflon.Oiling is way different on 4 stoke car HiPerf vs 2 stroke..I will see if I dig out a old coated piston
Cool thank you. I have taken quite a few measurements and even getting 3.375 closer to the bottom of the bore where skirt stability matters. But near top 3.378 and that’s with a near done finish..003 for cast and .008 for forged..................
So wsm also finally answered me and said their pistons are designed to go back into blocks that are honed so they are good to 3.380 so slightly larger then any oem replacement which was designed for a new engine. So either way look Iike it will be ok and if a little loose so be it. It’s also nice knowing someone purposely runs th this way so thank you.sounds like ya got what ya got and will probably do without startin' from scratch with all new holes.. might put new std. pistons in it and call it a day......... i always liked "loose" (cast or forged) with tha mercs anyway.... jmo
jan.. never had a problem with 'em either!
