1990 150 Drops RPMS
Hardcore
1990 yamaha 150. was running great and halfway through the day the motor now is 1) sluggish to plane, 2) will top out at 4000rpms and then drops to 3400rpms after a few seconds. it starts and idles and puts around great but its like it drops a cylinder at high rpms.
initially i thought it was fuel related so i rebuilt the carbs, replaced both fuel pumps, replaced spark plugs, have changed all filters, have run off separate fuel and fuel tanks, ran fuel directly to the carbs, compression is great and i have spark at idle but cant run a WOT test. it will run at 3400 all day but as soon as i get to 4000 it drops back down and is generally weak. any ideas? thanks.
99yam40
Re: 1990 150 Drops RPMS
Did you bypass fuel pumps and filter when doing this?
test ignition system components
peak voltage and ohm specs are in the manual
Timing light should show loss of spark when hooked to individual plug wires, but hard to do at WOT
Testing fuel pressure/vacuum is easier and cheaper than throwing parts at it and hoping
