1990 40hp Evinrude control box no power
Whoopbass
I bought a 1990 40hp Evinrude (untested) that I can't get started with the control box. I have tried to start the motor on a couple other sets of control boxes I have laying around and no luck. Motor is in neutal as well as the handle on the box. Kill switch is connected. Nothing.
I can jump start the motor off the solenoid and it runs fine. I pulled the kill switch while it was running and the motor stopped.
I opened up the control box and put a test light on all the connectors while turning the key and nothing lit up. The red plug looks clean on both ends and is secured tight.
The motor is on a stand with the control box laying on the ground if that matters?
What am I missing?
Check the fuse on the motor.----Near the solenoid.----A 20 amp about 5/8" long inside a rubber boot.----The lower units on these motors are not robust enough to carry the loads.----Use the best ( dealer ) gear oil in there.----Install a new water pump impeller as well.----Test the overheat warning horn too.
Whoopbass
I was hoping you would reply racerone.
It was the fuse. The fuse on this motor is located in a red rubber boot in the electrical block part of the motor. It looked like it was sealed to me so I never looked at it that close. Now to find some midget 20 amp fuses. Thanks
Whoopbass
"Test the overheat warning horn too"
One of the control boxes had an awful buzz when I turned the key over. Is that the overheat alarm? The buzz went away on that box but now it won't crank the motor.
I hooked up the other box that didn't have a buzz and would crank the motor but now it has that awful buzz but still works.
I haven't started the motor on either box just cranked the motor for a half second.
I wonder if this has anything to do with the tinfoil I wrapped around the burnt out fuse?
I will defintely be carrying spare fuses with me.
Sounds like the fuse blew again.----Some testing required to determine why the fuse is blowing.-----I refrain from trying to explain electrical stuff.----It can be frustrating to explain fuses and such to a novice from 1000 miles away.
Whoopbass
Found a good fuse and cranked it up. The buzz is still there but I think it has something to do with the VRO that was disconnected. When I unhook the VRO wires the buzz goes away.
Motor sounds good and it has good compression. LU is still good.
Thanks
Whoopbass
Premix on the stand
I thought the previous owner deleted the VRO but upon further inspection I believe its intact hence the alarm going off.
