1990 50hp evinrude
C-RAVEN
My main power on 16' fibreglass runabout is a 1990<br />50 hp 2-cylinder evinrude.<br />Motor runs good, and is well maintained.<br />question: what is the life expectancy of this type of engine ?<br />i was told you can expect about 15 years....<br />not sure if this is correct<br /><br />thanks
G DANE
Re: 1990 50hp evinrude
Welcome to this forum.<br /><br />Well maintained, these motors will last some place between 1500 and 3000 hrs. Some much more. You say average use of a pleasure boat is around 50 hrs a year. Lots of motors from the 60'ies still run. If cylinders get worn down, they can be rebuilded, cranck and bearings will last much longer.
JB
Hi, C-RAVEN.<br /><br />That 2 cylinder loop charged engine is/was one of the best outboard designs ever, and well ahead of it's time when introduced around 1970.<br /><br />With regular preventive maintenance it should last 30-40 years. Many of the early 70s engines are still in regular use. The ones that aren't died of neglect or abuse. They haven't worn out.<br /><br />You have a winner. Take good care of her and she will outlast you. :)
