1990 Chris Craft 254 Seahawk ( Refurb and upgrades)
Status
Not open for further replies.
lil buggy
Re: 1990 Chris Craft 254 Seahawk ( Refurb and upgrades)
great progress Budd,
seems to be going quick since you loacated the da sanders:eek::D
you should block it if your leaving it that way till tomorrow imho
good luck with the last lil bit
jbcurt00
You keep this up & get her all polished up & shiny, you may get a cease & desist flyover from a Metro Louisville PD helicopter when you put her in the Ohio for Thunder next month......
chriscraft254
It is going alot faster with the da sander and the fact that I was able to just scrape the paint off pretty easily.
Its got two jacks under her. Should be fine until morning, don't see two hydraulic jacks going bad in one nite. :facepalm: Knock on wood of coarse. And if they do, I am blaming you for jinxing me!!:mad:
One is a 3 ton, the other is my house lifter, 30 tons. Checked the fluid in the 30 ton and no seals leaking, should be good to go. the worst that can happen is it comes slamming down on the outdrive,lol:facepalm::eek:
Lol, Crap, next month!!! I better hurry up,lol
lil buggy
sorry to back things up a bit, but
now that i'm paying more attention
if you dont mind me askin.
what were the demensions on the taper
looks like 3/4 to 1inch at the bottom and about a half inch at the top
with a half inch channel for the lights
i wana break out the saw:eek: for some test strips for my project
dimensions will help speed things up for me
thanx in advance
ps now that your holdin me accountable:eek:,lol,
get out there and put at least 1 block under it, for my piece of mind at least
chriscraft254
thanx in advance
Rough cut was 3/4 X 1 1/2 inches. I cut the recess first, it is a 1/2 inch wide by 1/2 inch tall, Then routed the bottom edge with a roundover bit. Then eyeballed the tablesaw at a 12 degree angle to match the angle of the raised rib on the boat. I just eyeballed it to with the recessed part up so I could make sure it did not get into the routered edge. Hope that makes since for ya. If not, tmrw, I will take a pic for you.
lil buggy
thanx,
whadami gonna say no to pics?:D
i am an i boater after all!
seriously thanxs
i can wag it with that
jerryjerry05
Ive taken probably 100 boats off of the trailer.
Never once needed a truck.
All that you need is cement blocks or jack stands(I like blocks).
Lower the front of the boat almost to the ground.
Block up the rear corners.Don't block the center(just yet).
Using blocks and wood to protect the bottom.
Then jack up the front of the trailer (with the trailer jack) as far as it goes.
Place the floor jack just behind the first cross bar.Then with the floor jack,raise the front of the boat boat a bit more.
After it's raised the boat should be free from the trailer.Lower the front of the traler a bit.
Pull the trailer forward till it just about touches the axel or next cross bar.
Lower and repeat the process by moving the jack behind the next axel/crossbar.
Once the boat is completly clear of the rear axel start blocking the center, again with wood and blocks.
Then block the sides and under the rear center.
My present boat needed trailer work so I took it off the trailer rebuilt the trailer.
It's very stable while its off the trailer and on the blocks.
I've unloaded boats as big as 35 ft using this procedure.
Never dropped one.
chriscraft254
Never dropped one.
^^^^ Done it many, many times this way when I use to work at a boat yard. With two exceptions, no cinder blocks and no using the jack stand for jacking. Might work fine on light/smaller vessels, but not very safe on larger ones.
I wasn't removing the boat off the trailer, I was rolling the trailer out from under the boat to access the areas under the rollers. I have no need to block the boat as this work will all be done with-in a couple days, the keel supports and the roller cradling the boat is perfect for my small project in my small driveway,lol Should be winching her back on the trailer by the end of the day tomarrow.:)
lil buggy
i assume all went well lastnight?
i was sweatin the accountability thing:eek::D
chriscraft254
Yup, everything is good, my 30 ton jack is pretty much bullet proof. I have lifted a many houses with it. :p
chriscraft254
Bottom Update, Got a late start today, slept in but managed to get one side between rollers scraped down and then sanded with 600 film disks. Have some edging to do then 800 and maybe a 1000 grit. Going to polish these areas out after going over it with the 800 and see if its good. If not, will go to the 1000 grit.
After scraping
After sanding
After sprayed down, should look close to this once done
TitanTn
I'll be curious to hear what process you settle on. Sand with 600, 800, Finesse, Wax... or whatever ends up working for you.
chriscraft254
Already pretty set in stone if you look back through the thread. I wet sanded to 1500 on the sides and 3m compounded. Will get a couple coats of Woody's Triple XXX wax.
The bottom should not need as much because of the film disks, they finish/buff great. I think the 800 will probably be enough but we will see. I have the 1000 and am sure it won't need anything but wax afterwords. It will also get Woodys wax applied, though I am sure the wax will wear away under water. But it will stay waxed routinely.
evolution1985
ok This has got to be one of my favourite threads on here. The detail work is awesome. That boat will probably outlast us all after the amount of love you are giving it. :D
I applaud you, seriously. Although Most iBoaters share the same passion and love for their boats its always great to see an older boat in far better condition than most of the new-newish boats that can be bought on the market, both here where I am and where you are. I doubt that there are many boats of your era that can pull up alongside a brand new boat just put in the water for the first time and make it look shoddy. You should be very proud of yourself and I hope that she gives you many many years of happy boating.
ok im done with brown nosing :rolleyes: but I honestly think that you do deserve the compliments.
Best regards mate and thanks for taking the time to share with us.
Nick
chriscraft254
Nick
Nick, Thankyou so much for the complements, they are much appreciated:). Thankyou ALL for the compliments and taking the time to following me through this process.:) It truly has been my pleasure sharing this refurbish with everyone here. Its really what i enjoy and I love sharing it with like minded people.
I started out very young with many 100s of happy hours with my family on various boats, its just always been a part of who I am. Hell, I use to skip school, not to go get into trouble, but to go boating. Growing up I dreamed of having a boat of my own someday. I love all different kinds of boats and any time spent on the water, thus the reason for making this boat shine.
I'd like to take a second and explain something I truly believe. There is a boat out there that just suits the owner, kinda like having the right tie,lol:) Or your favorite pair of ripped up jeans. I knew when I came across this boat, it was me. I saw it listed on ebay and just knew the minute I saw her, that I had to have it. Not because it was shiny or big or better than anyone elses boat. But because it was a diamond in the rough in my eyes. It had everything that I truly would have wanted on a boat and it was cheap enough for me to actually think about a purchase and actually afford.
I saw what it could be instead of what it was. I started thinking about changes I could make to her before it even got home to my driveway. People talk about "droppin sandwich time", Thats exactly what it was for me when I saw this boat.
The previous owner was really a nice guy and he and his wife had just had a newborn. He was in the military also, so we had that in common. He was very forthright about the condition and what he had been through as far as replacing motor and still having issues. I told him that if it needed a new motor, it was still a deal at the price he was offering her at. His wife got a new more reliable boat that she could feel safe on with youngens.
Things just align sometimes and I am really happy to have had the chance to restore this old battle wagon. The previous owner and I still stay in contact on accation. This boat was a challenge in different ways. Mostly just because there was very little, I mean VERY little info out there about them when I purchased her. Still think its a rare breed compared to some others.
I knew the history of Chris Craft and all it stands for. Its one of the corner stone companies as far as I am concerned as far as boat building history. Can't wait to pull up to one of those brand new boats so I can admire them in my old shining battle wagon.:D
Don't know what got me started on all that, I am done rambling. But seriously, I have really enjoyed the project and all the discusions and humor of this site. Cheers to you Mate.
25thmustang
Although this means very little, I would take your "old" battlewagon over any new comparable boat. More character to the old ones.
Keep posting up progress. It has me motivated and I even started my thread over here. :D
chriscraft254
:D Awesome man, where is the link? I agree with you, I like the charactor of older boats also. But there are a few new ones I wouldn't pass up if given to me.;) Should add your thread link to the bottom signature.
By the way, what parts of Ct are you from. I grew up in Stamford and Darien Ct. Sister is still in Ct. Wish I had my boat when I was running Long Island Sound.
BSnB
I can only echo what Nick said and agree with you as well CC. Sometimes a boat just speaks to you. To quote you...
it was me. I saw it listed on ebay and just knew the minute I saw her, that I had to have it. Not because it was shiny or big or better than anyone elses boat. But because it was a diamond in the rough in my eyes. It had everything that I truly would have wanted on a boat"
That couldn't have been said better.
Mike
evolution1985
First of all, your welcome, and yep even amongst that rambling I managed to make sense of it, and I would have to agree with you. Even though I am in the process of aquiring a Niche' ski boat company, I will still take my old (97) wellcraft out for preference, I just love how it feels to be in and drive. Although until I can make a start on it again it might be awhile :facepalm:
Also do you mind if I ask what you did in the military? I was in the australian army for awhile and on many occasions I worked with the american military. GREAT guys (and gals :D), really friendly, and dam good at their job. and the BIGGEST thing I found was at least they knew how to have a laugh :D. although Only one of the ones that I worked with actually like vegimite, I don't get it, IT rocks............ as long as you only use a tiny bit :rolleyes:
Anyways thats my mini rant done,
best wishes mate
lil buggy
Thats not a rant its an iboats pledge right there
we the people,,,,
well said
thanks for sharing your history with us.:D
you are really picken up speed.
hull is lookin good.
i hope you light up thunder on the river
remember each one of those led's is for each i boater that you inspired or reinspired
all the best
my glass is raised for you:D
thanks
Status
