1990 Chris Craft 254 Seahawk ( Refurb and upgrades)
Status
Not open for further replies.
bldgengineer
Re: 1990 Chris Craft 254 Seahawk ( Refurb and upgrades)
FINALLY brought home my 215 WA today! Sea trial went fantastic. Only problem was the electronics went out due to the battery going bad so the dealer replaced both batteries. By the way, for the guy asking me about the floor drains, they are going out to suppers leading to the each side of the boat.
According to the GPS, she planed at around 20mph and topped out at around 36mph. I was also able to get her down to about 4-5mph.
I'm REALLY happy with it AND everybody at the dealership. Now I just have to get me a boat cover and a bag to keep all the crap in.
Also, the transom plug is just a screw in brass plug. Will this suffice or do any of you guys recommend replacing it with something else?
grunt51
which fuel gauge is typically assigned to the main tank ? any experience with gelcoat blisters? how far up the gunwhale does the bottom paint extend ?
fishinfiend
Ok, so the boat was in rough shape cosmetically but was in pretty good shape overall. First thing I did when I got her home was took a long nap, it was a rough trip going to northern virginia to pick her up and a semi almost killed me on the way home. My truck did not appreciate the trip through the mountains at all! I got started by pulling off the coaming pads, they were original and just shot. You can see in the above pics all the teak had been dark stained for some reason by the previous owners. I took all the teak off and started sanding. I also bought some rough lumber teak to make some step pads for the gunnels. Bow pulpit, boxes under helm chairs, door for cuddy, and rear seat supports are all teak. I removed the side gunnel boxes and boxes under the helm seats to paint them because they were faded badly. Didn't have alot of cash to put into the boat at this point, so I was doing what I could afford. I am a big fan of teak and do realize its not for everyone because it does take constant maintenance to keep it looking good. I have thought about west systems or something comparable but for now teak oil will be the protectant.
Very nice work what kind of paint did you use and what was the method used for painting them ? (side boxes)
southkogs
OUCH!! Ya' chunked the stern drive :eek: Sorry to hear that. If it's any consolation, we can say I blew a head gasket in your honor :facepalm:
Here's the funny part: Since mines in layup right now I started thinkin', "Hmmmmm, maybe I should buff the hull out, rework the swim deck and think about some lights ..." I think you're rubbing off on me :D
Hope we can both be splashed again soon!
ben2go
I splashed this morning.That cast iron tub really hurt.I need a new anti slip tub mat. :facepalm:
BSnB
Here is the light housing with 145 leds installed behind glass. These are one color lights just for testing. I will make a longer version also with 300 leds in them. Think this will work out well, we shall see. Still alot of fab work and modifications probably, but its getting there. everything will be soldiered and the material I am using will act as its own heat sink.
Ummmm....knock, knock....:rolleyes: Sorry about your lower unit and all...logs, grinding sounds, yada, yada, yada....
Underwater lights???
Seriously, sorry to hear about your drive problem. That sucks. I hope you're close to getting her back in the water.
suthrnboy
Ok, well, the next two things I think are very cool! I had been looking for some led interior lighting for under the new gunnel rod holders and a couple other places. I found what I wanted, they are Rgb lights, they can change 7 differnet colors and you can dim them as much as you want. I love that fact they dim because different conditions can call for different shades of light and brightness. I will be using the red mainly at night while underway. Red doesn't effect your night vision. I will be using the white at night while cleaning the boat, loading fish, or rigging Lines. Will use the other colors just because they are cool looking. lol They come with a remote and can flash, fade, dim, or static on each color. I am very pleased with the product and can't wait to use them on the water. The pics are of the boat sitting in the driveway, My camera does not do real well with the blue and red colors.
Install took time, but they were pretty easy to install. They have a control box that I mounted under the helm. The control box is where all your wiring goes to for the lights. I mounted this control box next to the side scan box for the lowrance. Again, easy access and the power is coming from the new buss teminal which has its own fuses.
You can see the install below, I simply scribed the light profile onto the rod holder, then with a zip router, carefully routed out the profile. Then all I had to do is run the lights all the way through, remove the self stick backing tape and apply. I then ran the wiring to the lights through the gunnels and up to the control box under the helm.
Where did you purchase your under the rail led strips? I have been looking at doing the same thing to my Hydra Sports.
Chris
chriscraft254
Ok guys, I'm back. Sorry for the no replies lately or for the last couple months. Life has a way of getting in the way and my time had to be refocused for a bit.
I am back now and have a few things in the works, though most of them not boat related.
I did finally get my radar shipped out. The unit had water in it and I will say Lowrance service was second to none in my transaction with them. Total turn around time was ten days from me shipping it to them. They sent me the 3g model instead of replacing the 2g model. SWEEEEET! Anyway all good there. :)
The underwater lights are still being modified and worked up, I have had very little time to do much with it, but that will be changing here soon.
The boat is at idel in the drive and I plan on leaving it that way until funds will permit the new outdrive install. Probably won't see the water tell next spring, but thats ok, because I really don't have the time to use it right now anyway.
Hope all is well with my friends here and again, sorry for the delay in response, I will go back later and answer/respond anything I have missed. ;)
ben2go
Plug away.If ya getting to work regularly,enjoy it.Never know when this country is gonna turn turtle again.We're barely floating now.
lil buggy
Welcome back Budd!
We missed ya here. Glad the radar is up to speed.
Hope all is well
jbcurt00
Great article, but there was still no mention as to where he purchased all of his led stuff.
Chris
PM Bud (CC254) or lil buggy (he posted just above your last post here). I don't know if they used the same setup or light supplier, but lil buggy is using very similar w/ similar controls. Might be the same...
lil buggy
Suthrnboy, sorry i coulda sworn it was in the thread,( all the info is burried somewhere on both our refurb threads,), cc254 got his on fleabay,, and i got mine on kamazon at one point we had the same strips, and remotes, but different control boxes but cc is upgrading his strips for more light. anyway if you google waterproof rgb led strips you will come up with a few options
heres my set
Ledwholesalers IP67 Waterproof 16.4 Ft RGB Color Changing Kit with LED Flexible Strip, 44 Button Controller + Remote and 12 Volt Power Supply, 2038kit
by LEDwholesalers LED Strip Lights
is the company name. the ad has changed since i purchased mine, mine are the white strips encased in sillycone(not resin or in a sleeve )
hope it helps
mrdjflores
welcome back bud...we all know how life's priorities and fun priorities can get switched around from time to time....it's probably been atleast a month since i've touched my boat.
mrdjflores
surely you haven't put this gem away for the winter yet???
chriscraft254
Hey guys. Just stopping in to say hello and wish everyone Happy Holidays! I will be spending the next couple days catching up on all your projects. Sorry about the no response disappear act. Just had to give boating a rest for a bit and get back to work,lol
Anyway, hope all is well with everyone and chat with ya soon. :director: And the new smileys rock! :)
jbcurt00
Nice to have you back, got lightbox?
Status
