First I would like to say I am new to this site and it is full of great information. Now the bad news. Went out on Friday and the motor ran fine all day. On Saturday put the and ran for about two hours with no issues. Needed to get gas so pulled to the dock to get the trailer. The motor died. Started the motor back up but each time the boat would die when putting the boat in gear. Used the trolling motor to get on the trailer. Thought maybe we were low on gas and that was the issue. Got gas and put the boat back in the lake. Tried to start the boat and it was very sluggish and wouldn't start. Tried a second time and all I got was a clunk. Thought maybe the battery was drained so pulled out of the lake and hooked the charger up. Battery was fully charged in 30 minutes so not a battery issue. Tried to start again after fully charged and all I got was a clunk again. Came home and thought maybe loose connection or battery terminal. Replaced the terminals and check connections and all were good. Tried to start same clunk sound. The started was engaging the fly wheel but wouldn't turn. Thought the started so I jumped straight to the battery and same clunk. Tried to turn the fly wheel and it would not turn. Motor is seized. Pulled the spark plugs out and when I did the top plug was all rusted as was the spring the the boot. Other three spark plugs looked brand new. Nice and shiny. Checked on the site and it mentioned to pour some oil in the spark plug holes and let set to loosen up the engine. When I did the oil leaked from the carburetor, the bottom on the boat near or out of the water intakes and somewhere about halfway down the length of the engine. My questions are is this normal should the oil leak from some many places? I know I have some issues but does it sound like this motor is repairable and if so at a cost that makes it worth repairing?
