jerryjerry05
- May 7, 2008
- 18,095
NO,NO------Both carburetors operate EXACTLY the same way.----And air that goes into the top carburetor can not finds its way to the bottom 2 cylinders.
The carbs ARE connected by an "equalizer tube" on the intake.
The only difference is the fuel inlet and the throttle roller.
I believe the tab on the float should be pointing down.(bottom)
The carbs are NOT for low speed and high speed.
The jets and air screw do that job.
The air screw and jet controls the operation at low speed.
Then after the throttle's activated the high speed jets take over.
Running a motor dry???
That can cause scoring of the cylinder walls.
The 120 has screws on the bottom of the carb you can loosen to drain.
Or use Stabil to treat the gas.
