1990 force 120hp outboard HELP!
The Force power
when I ordered my kit and yours will be too, the kit is generic and will ship all the seals/o-rings needed.
Ebay is a great place to buy from, just check out the seller first!
Search fort he original part# first.
the kit will contain the parts needed for single or dual port-exhaust
The Force power
You have done such an amazing job on your boat & motor; you're on the home stretch.
Just a word of caution; do not pull/unscrew the shift-pin/screw from the lower-unit.
(I made that mistake)
The Force power
Is yours with the anoid around the prop-shaft or do you see the bearing-carrier after the prop is removed?
puffitu
Anode...
So...I went out today for about 5 hours with no particular destination; just buzzing around as usual, I noticed my fuel efficiency was really bad-the fuel gage as everything else works perfectly but I was consuming a lot of gas. went back in. Decided to look under the hat and found one of the re circulating tubes/hoses had a slice in it. This was what was dripping out. Is it possible that the leaking fuel mix was making its way all the way down the leg and somehow going out through or around the prop??Anyways, I fixed the tubing and no more leak!
