The Force power
- Feb 3, 2019
- 2,358
At what RPMs is it idle in Neural?So she's idling fine but dies going into gear on the water, works fine on muffs... I'm told carburator idle ajustment?
I guess someone did not follow the information I providedThe idle speed should be 7-800 RPM i water and gear, 1100-1200 RPM at muffs.
If the idle speed is correct but it still stop when put in gear you maybe have the air fuel mixture screws at the carbs set to lean.
Start setting should be 1-1 1/4 turn out from seated and adjust in 1/8 turns each time.
Let the engine run about 10-15 seconds between each adjust. It has to adapt to the new setting.
Man. You know. People try, this stuff is complicated. It's hard to even understand how to read the language more experienced boaters share.I guess someone did not follow the information I provided
I hear you & will get you through this.Man. You know. People try, this stuff is complicated. It's hard to even understand how to read the language more experienced boaters share.
I set my idle, she's roaring at 3000 RPM. Idle screw totally backed out, playing with carbs. It turns out my butterfly flaps needed to be adjusted big time -- I think -- so it's one thing to give advise, but it's another to understand it. Thank you for replying, it takes time to process, understand, and apply.
