Just removed the Cylinder Head Cover and Head and the found no scarring on the cylinder walls. Suspected a Head Gasket problem and found lots of corrosion possibly breaking the gasket seal. Also found carbon build-up on the piston heads and the Head itself. Thermostat is corroded and shot.
Should I leave the piston heads alone?
What should I use to clean the carbon off the head?
Anything else I should do at this point while the head is off?
