JASinIL2006
- Feb 10, 2012
- 5,738
Where are the bubbles you're worried about? If they are the light spots (second picture, top near the center) where the 'glass is following the curve of your fillet between the double and single thicknesses of the plywood, the only ways I found were to either make the curve more gradual or to really baby the glass and keep hitting it with a roller as the resin kicked.
I'm not sure I'd worry about it too much. If it REALLY bugs you, you can grind it off and try again. (I don't think I would.) If your concerned about leaving a cavity where water might get in (or collect), you can get a hypodermic needle and inject some resin into the bubble. (It helps to drill a small air relief hole on the opposite side of the bubble from where you inject.) I got a few needles at a farm equipment store.
If the bubble is away from where it's likely to be exposed by water, I'd probably leave it alone. If it's down near the bottom of the transom where it might be exposed to bilge water, I'd be pretty invested in doing something about the bubble. You don't want to do all this work and not protect the wood.
Looks like you're making some progress, despite all the other stuff going on in your life.
