1990 Lund Pro-V 1700
1992 Johnson 90HP V-4
2000 Evinrude 9.9HP Kicker
Need help with transom repair disassembly.
I bought this boat for a new project. The boat needs a complete overhaul (All wood flooring replaced and hull painted). I noticed the transom has small through wall pin holes with white powder around edges. The center of the transom is solid (Checked Through Splashwell Access Port). Previous owner had a kicker motor installed on both the "Port and Starboard" side of the transom at one time. The transom leakage started here due to top cap damage from the kicker motor. This would explain why there is no rotting taking place in the center. What can I do to prevent this pitting prior to installing a new transom? Also any input on self-sealing rivits, marine primer/paint? The top 9 inch wide top rail plate overlaps transom cap. Any one out there know if I need to remove this for access? I am in the process of removing the splash well. The boat structure is built like a tank and the motor runs great. I have pictures, not sure the right way to post them.
Any help would greatly be appreciated.
Thanks,
1morefish
Thanks,
1morefish
