Need to replace the ignition switch and I'm not sure if I can use a universal switch or not... it's a panel mount (not on the control box), with push to choke. It appears to be the original switch, as the wires on the back are in an epoxy/resin material, and there are no splices that I can see...
My question concerns the fact that there are 4 pairs of wires (2 red, 2 pink, 2black and 2 blk/yellow) and also a single yellow/red and a single yellow/blk coming from the epoxy on the back of the switch, for a total of 10 wires.
My problem is that all the ignition switches that I've seen have just 6 terminals on them... my guess is that the pairs (the 2 red for example) should go together on the same terminal, which would mean that the 4 pairs and 2 singles that I mentioned above would work on a 6 terminal switch...
Would this be correct...??
Just a guess, but I'm hoping someone can confirm or correct my theory before I do something stupid here... my clymer shop manual is good, but it's not much help in this case.
Thanks very much for your assistance.
