gsxrdan
- Aug 28, 2016
- 317
That all looks very familiar! Good luck! Im doing the same type o job atm, and from what ive read and seen you probably need to take it all out... all the foam, all the deck and stringers and other bits - and be prepared to drill test holes in the transom to be sure of its soundness.
And welcome to the unholy world of grinding :lol:
My fav tool for cutting the glass seams down low was thin stainless steel cutting discs for the grinder, only used 2 for the whole boat, and then 12 of the 32 grit flappy discs to grind grind grind - knock out the dust from your respirator frequently or ull get light headed - and then grind grind grind
