jc55
- Nov 3, 2006
- 665
On to finish up the documentation!!! Here's the Bilge. I have a primary and a back up Rule 1500 wired to separate batteries. The back up is on an aluminum bracket I made and both pumps discharge through a "Y-valve".
I installed a remote station with bus bars at the stern fed by 4 gauge battery cables from the pilot house. (You get cheap fuse holders and automotive wiring on the most expensive jack plate you can buy)...but I digress. I can add a kicker here, jump start other boats, or attach my portable bilge pump.
My solar controller and the new seat cushions Woodonglass made for me!
Under the seat, The little bosch style relay energizes when the ignition is on to kick off the solar feed. That way, the panel and alternator aren't feeding batteries at the same time.
I deleted the scuppers and added pluggable deck drains down into the bilge until I know how the waterline is affected with the new motor. I can add scuppers next season if needed.
I had theses storage boxes repainted. The hatches were bad, so I let them soak in bleach and they're 10x better...
My custom alarm system(LED in top left corner) tells me whenever the door, hatches, or outboard alarms are open. New gauges, and "secret" toggle switch security functions. The Navsea sticker is from her commercial days as an ordinance recovery with side scan sonar...how cool a legacy is that!
I made a new thresh hold from marine ply, then several coats of Rustoleum white. I glued it in with 3M 5200. The less holes in the deck the better. The last one didn't rot but I destroyed it getting it out.
New hatch embedded in 5200. I bolted it in and it seems to be flat enough. Cleaned the excess with acetone and I'll run a final bead of Life Calk when it cures in 3 or 4 months
Hopefully that sounds right?
Tying up loose ends and waiting for the weather to break!!!
