1990 vs 1992 4.3 block swap
Chris51280
Ensign
Since rotating assembly's need to stay together I don't really want to swap pistons. I think it will be ok. No damage on the cylinder walls
Your not trying to swap a rotating assembly from one block to another without machining and new bearings pistons and rings are you?
Chris51280
Ensign
No. Plan is to use the old pistons, block, crank, pushrods, lifters, con rods, damper, flywheel from my good motor
From the old mercruiser I will use the heads, camshaft, intake, carb, distributor, starter, water pump,oil pan, timing cover.
Things that will be new are marine gaskets, bearings which are oversize, rings, oil pump, timing chain set,
So, do I need a new piston?
Scott06
That's an odd wear mark, would assume you have matching scoring in the cylinder it came out of? Although in a pinch you probably could dress up that piston, I wouldn't reuse it. Especially since this engine has been gone through once already, Best advice I would give you is to clean up all the parts, take them to a machine shop and have them measure bores, crank journals, and rod big ends, plus check out heads before you order any parts. A decent shop will be able to tell you exactly what is past wear limits and correct size bearings etc you need. This far into it with an unknown history you might as well take your time and get it right
Chris51280
Ensign
There is hardly any wear on the crank and the bores look good. A little shine on the side of the bores but nothing a little honing won't solve. The bearings looked good as well and it could have easily run another 100k without problems. Since im changing the cam and im in there I do all new bearings. If i take it to a machine shop, I might as well buy a short block from a marine super for 1200. The new parts run me $450 with the donor engine $225. I have access to micrometers and can check the crank if I want to but im not concerned with the wear. This would definitely show right now and it looks good. Will post a picture of the crank..
Chris51280
Ensign
[No message]
Chris51280
Ensign
That was just cleaned with a rag. So the surface might look rougher than it is with the camera flash.
Chris51280
Ensign
Cyl. 1-3-5. The piston came from #3
what do the crank journals mic to?
the fact that you pulled the rotating assembly apart, I assume you plan on putting in new bearings?
you have to make sure the intake manifold clears the balance shaft
Chris51280
Ensign
Yes. New bearings. Rods are 20 under and mains are 30 under. No balance shaft on both. Kept the same style motor
Chris51280
Ensign
Not sure if I caused the scuffing. When i took out the piston, the top ridge of the cylinder wall wasn't cleaned. So there was carbon deposit that was pushed out when I pushed out the piston. I can't remember how much deposit was there. May that have caused this? That explains why there are no scuff marks below the 1st ring.
Chris51280
Ensign
Here is how it looked before I took them out
Chris51280
Ensign
I measured the crank today and I'm within spec on the main and con rod journals. I took into consideration the undersize of .02" on the mains and .03 on the con rod journals.
Rod measured 2.2187-2.2192" stock is 2.2487-2.2497.
Main measured 2.4280-2.4285" stock is 2.448-2.449".
I personally would get a new crank. I hate undersized cranks (not to mention a new crank is cheaper than reconditioning a used one)
Scott06
Carbon wouldn't make those marks getting a piston out of the bore. If it's not scratched in the bore the piston must have been that way when it was put in.
.030 seems like a big undersize on the crank. I don't think I even had to do that much grinding rebuilding a chevy V6 with a spun rod bearing. As long as your confident in your measurements should work out.
Chris51280
Ensign
Yup. I started out as a mechanic assembling machines and now have an engineering degree. I worked on a Honda cb550 from 1977 and rebuild the engine. Only put new rings in since everything was still ok.
I'm just running into new things with every thing and like a second opinion.
the piston skirt looks good. It's just the top ring to the side. Maybe something got it there and scuffed it
thanks scott
Chris51280
Ensign
Cleaned up the block some more. Have to get the other freeze plug out to get the other cam bearing out. The bores cleaned up ok I think. Some shadows on the top. I don't want to hone too much. Only to get new cross hatching in and deglaze it.
Chris51280
Ensign
Ok. I started to take the mercruiser apart. The starter wheel is much thicker than the the donor engines. I thought that the rotating assemblys need to stay together. Will,this be a problem if I use the starter wheel on the new engine?
achris
More fish than mountain goat
That's a flex-plate, for an automatic transmission, not a flywheel (automatics use a flex-plate that the torque converter bolts to. Manuals use a flywheel that the clutch assembly bolts to). I think you said both blocks are non-balance shaft, so the flywheel should fit onto the crankshaft of the engine you're using. I would take the whole rotating assembly (Crank, pistons and rods, flywheel, harmonic balance) to a machine shop and have them balanced.
Chris......
DouglasW
Don't throw away the flex plate. They crack more often than you might think and folks need replacements. You may get a few bucks for it. Well,,, maybe not for a V6, but what do I know ;-)
