To the people with wisdom and knowledge...
I have a 1991 120 HP Force Outboard (H1208E91H) that needs a piston replaced (compression test 120, 120, 120, 30 from top to bottom). The number 4 piston has a hole in it, and scored cylinder.
I've hoisted it off the boat and have it down to just the powerhead.
My plan is to replace all 4 piston and rings at +20 and bore the cylinders at +20 (a couple of the scores looked deep, so I figured +20 to be safe).
Questions:
1) What gasket sets do I need for this job? I see all kinds of parts lists here: http://www.boats.net/parts/search/Merc/Force/1991/H1208E91H/CYLINDER BLOCK/parts.html
At the bottom of the list appears to be gasket "sets" but I'm not sure if they contain everything I need.
2) Also, and mandatory special tools required?
3) Anything else I should consider replacing while I am at it?
4) I'm based in Canada - any parts dealers you can recommend?
5) Is it possible to order +20 piston, rings, gasket set all from one spot?
Appreciate any input and advice you may have regarding this task. I have the shop manual and 2 mechanically inclined people (bike engine rebuild experience) helping.
Thanks!
Peter
Questions:
Thanks!
Peter
