Yes casters are good to go. Yes, you can run the motor on the stand but.. you must use Muffs. Buy em at WalMart and hook up water Hose..
I went ahead and built a motor stand. The motor says it weighs 285. Do you think I built the stand strong enough? I used pt 2x6's, stainless #10 2-1/2 screws, and liquid nails heavy duty construction adhesive.
Edit also a square scrap piece of pt wood at the bottom.
I'm obviously not a skilled carpenter....
Check the voltage while trying to crank. Could also be a bad solenoid. If you check voltage and it is dropping severely while trying to crank and you know batteries are good. Try starting by. Mechanically jumping solenoid.....a screw driver across two main nuts on solenoid. If problem still exists pull your plugs out and check again with less pressure against starter. See if the voltages change and make note of what they are before and during trying to crank...and post them back here.
Maybe I'm wrong, but that is what it looks like to me.
OK, yeah, it could be the PO owners attempt at salvaging an extra season of boating from an already rotting transom...
All four of the holes were offset about the same amount???
The original engine bolt holes may have already gone "soft"...
Just caught up on your cranking problems...
From here it looks like a definite electrical connection problem...electrical gremlins can act exactly the way they are happening to you...good crank sometimes, sometimes not...
Look for every single connection related to starting the engine, inspect, clean and make sure they are all tight...especially the grounds...
Any suspicious wires or wire connections should be remade...when the engine is cranking, it is pulling a very high amperage draw, if there are any weak links, this is when they will most likely rear their ugly heads...
Take a jumper cable and come off positive side only over to solenoid. Find the wire (large) coming off solenoid and going to starter. Just firmly press up against and it will turn over starter....if this fixes your problems it is a connection between solenoid and battery....or solenoid itself. If this does not fix the problem it is the starter.
Cylinder | Test 1 Pressure (PSI) | Test 2 Pressure (PSI) |
1 | 135 | 140 |
2 | 135 | 140 |
3 | 140 | 140 |
Finished removing all the carpet
I have a 1991 Capri that looks exactly like yours. I have water pooling in the back when it rains or if we get too much water in it from getting in and out. There is no where for the water to drain to the bottom so that it can be pumped out with the bildge or for it to drain out the hole in the bottom when it is on trailer. Anyone else have the same problem and can a hole be safely cut near the sides of the middle to let it go down to the bildge? I wonder if this is why the boat you have and many others have a rotten wood problem? I'd like to prevent this from happening to mine. Thanks for any who can help.
