island mike
- Jul 31, 2011
- 440
Re: 1991 BAYLINER deck rot question
There you go again with the 3m 2500!
First of all its not a filler,And does not stick well to bare wood,Not the correct way to fill a hole,Use resin mixed with Chopped fiber or get a can of adhesive filler.Do it tight.
Regards I mike
Start low and work up.... Look where the stringers butt the transom.... Are you taking core samples? 3/8" drill bit go in about half way... wrap tape around drill bit at about 1" so you have a depth gauge to work with....don't driil thru the outer skin. If you find wet damp dark wood chips=rot.....clean dry light colored chips =good.... if it's all good just fill core holes with 3m 5200.
Regards I mike
