I recently purchased a boat with a 1991 Evinrude Intruder 150 engine. The motor will start up, but only stays on for 5-15 seconds. When I took the motor cover off, I noticed some fuel coming from one of the inlets. I can replicate the problem when I pump fuel into the system. The attached video shows the problem.
Has anyone had this problem? If so, do I need to replace the entire fuel inlet (http://www.marineengine.com/newparts/part_details.php?pnum=OMC0433364&pass_title=0433364+:), or just an o-ring? Or is there another fix?
Thanks so much!
Thanks so much!
