bruceb58
- Mar 5, 2006
- 30,591
Re: 1991 Four Winns 4.3 Cobra overheat and now stern drive noise
There is no upper and lower unit gear lube. It is all one cavity. You drain from the lower hole and fill from the middle until it comes out the top dipstick hole. Is that how you filled it?I changed the lower gear lube and greased the Gimbal bearing.
