My outboard is running a little bit too fast at idle, how I sould adjust the linkage to reduce the speed ? by unbolting the throttle cable bracket from the cylinder and rotating it a couple of turns?
also how should I adjust the idle mixture (top screw on the left side of the carb) right now it's at 2 1/4 turn from bottom which happend to be about 1 turn back from when it start shudder.
this outboard will be used as a kicker only for trolling at slow speed
thanks for the help
thanks for the help
