Re: 1991 Mercury 135 V6 only firing on 3 and 5.
Finally got my DVA, an es530, flywheel puller, manual, and strap wrench.
I checked the ignition and results are:
stator
blue- 290v
blue/white-27v
red- 27v
red/white 27v
The Blue/white should be about the same as the blue. That would take out one switchbox. Makes me wonder if you have crossed wiring to the trigger or coils in addition to all the other faults. Try it again disconnected to isolate whether the stator or the switchbox is at fault. If the stator tests correctly in both ohms and voltage when disconnected, then the switchbox is at fault.
trigger
all leads in black sleeve- 3v
switch box
SW stop circuit- 300v on both
SW bias circuit- 1.5v on both
I assume you didn't test the yellow sleeve because you couldn't get to it.
Peak on the trigger about double bias looks good. You should disconnect the jumper and test on each switchbox.
all tests with leads connected. spark advance and lube alert disconnected.
Am I supposed to disconnect the white/black stripe wire between the switch
boxes when checking the bias circuit of each?
Yes
The stator appeared fine no signs of rubbing, no play in crankshaft, correct
1 and 1/16 stator screws, stator/ trigger holder in good shape. The top of
the stator appeared to have possibly gotten hot, will post pic.
Finish the testing, it's probably bad.
The trigger was loosely in place(SLOP), had some signs of rubbing, and had
cracks on the top but it checked out ok with the VOM and DVA.
It just lays under the stator with plenty of freedom. It is moved by the throttle linkage for timing. If the wires are frayed or the sleeving damage where they come out sternward from under the stator, replace it. That's where they usually fail. Also, with all 6 stator leads disconnected, test between each wire in one sleeve and ground with the ohmmeter on a high range while pressing downward and rotating the trigger. You're looking for a ground fault that will reliably take one cylinder out of a switchbox.
So should I just replace the stator after sorting out the wiring?
Be sure the rectifier is good. Theoretically a short there shouldn't hurt, but it might overheat the stator.
Perhaps the hack mechanic spun a 40 amp flywheel over the stator for a short time, weakening it.
John what wires do I need to splice, and can I just leave the spark advance
and lube alert disconnected or is there more to it. Should I leave the voltage
regulator connected?
You only have to splice wires if you're putting in a later pulse technology regulator. Then it would be obvious, as the color codes are about the same. The connectors are different.
If you don't have oil injection on it, remove and discard the lube alert. Leave the temp switch and the wire to the cannon plug harness under a screw on the terminal strip mounted above the switchboxes.
You may discard the advance module. Set your WOT timing at 23 degrees BTDC. You're hunting a gremlin, so it helps to discard gremlin houses.
If there's any obvious damage to the voltage regulator or it's harness, discard it. If you wish you could hook it up later, and see if it is effective. It shouldn't even have any effect unless the battery is fully charged. If you discard it, your battery will need reasonable periodic maintenance.
hope it helps
John
