mkast
- Nov 6, 2002
- 1,934
Re: 1991 v-6 carb. went kaboom!!!
Piston engines in aircraft usually use 100 grade engine oil, what you would call 50 weight.
When you fly to cold climates, and hanger space isn't available, some aircraft manufacturers used an oil dilution valve to pump aviation fuel (av gas) into the crankcase to thin out the engine oil so the engine would start easier the following day. After start up, the engine was run for xxx amount of time to evaporate the fuel before takeoff. For all those cringing, most were dry sump systems, but not all.
Pass the Olympic torch, so I can light my cigarette!
