nokoboater1
- Feb 19, 2006
- 2
I am an auto tech, and just bought a used 28 hp johnson .Upon examining the motor I found that the maximum spark advance set screw was backed off, I have no idea where it was. I have a service manual and went thru the procedures but not having a test wheel like the manual requires I am at a loss. Do you think the boat pointed at a dock with the prop I would be able to set the wot timing to specs? If not, do you have any suggestions to help with my propblem? Also do you think running a prop instead of a test wheel provide the proper rpm to set wot timing? thanks!
