Re: 1992 70hp Force motor cam shaft just a hair forward to much, causing high idle
Ok, been trying to adjust all this, in between job and small time I have til the weekend. I dont have much time before I head to work. So here is what I have done so far.
I have disconnected the little ball connection to the cam. The spring on the roller was a little sticky before it returned the carb completely closed, as I moved it back and forth, it seemed to snap back in place to shut the carb.
Next I adjusted the roller, cam to line up just centered on the line, like your pics above. This is while it is in neutral.
I adjusted the the two ends on the ball/throttle connnections, and put nut back on cam.
Now when the cam is adjusted to the point where centered with the cam, it is still just pushing a tad on the cam, also adjusted the cam roller screw, but still pushing just enough for carb to be open to cause high idle.
Now if I pull tower arm back while in neutral, it will move back almost 3/4 to an 1''.
I have not checked compression, nor timimg. So I will have to do that this weekend.
So from what I have read that everyone has posted, it seems to me it could be throttle cable not completely returning to idle, or possibly the throttle tower having a problem. Am I on the right track? Can I pull out slack by adjusting spring loaded cable at the control lever? I will follow more of the steps below that are listed by Juggz too. I dont wanna move to fast and get wreckless, and break or tear something up. Its so close to running great. I will post follow up posts as I keep working on it. Thanks for all your help!
