1992 Evinrude V90 crossflow thermostat issue
Crossflow90
good day everyone , I just joined
I have assembled the thermostat housing with new stats, valves etc today . I notice the cork seals sitting in the recesses that the 2 stats sit on, seem to stand out quite a bit above the plastic, so when I put the gasket over it, it does not seem to sit flush onto the plastic. .
1.Is that normal for a new cork seal to sit out like that and do I just have to tighten the 3 bolts until the gasket is flush with the surface?
2. Do i use permatex aviation on both sides of the gasket ie onto the plastic housing as well as onto the metal surface of motor side
rothfm
Ensign
Yes those corks sit up a bit higher, noticable when the gasket is around them also. When It all squishes together it will be fine.
Right or wrong, I always use permatex #2 lightely on all sides of the housing parts and both sides of gaskets....not alot as you dont want any migrating off and getting into that area
havoc_squad
Yes, Permatex aviation form a gasket goes on all sides of the gaskets when assembling.
When you put enough to properly coat the gaskets well but do not over-do it, you should not have to worry about coating the thermostat housing or the midsection surface where it mounts.
That will prevent you from over-doing it near the middle vent hole on the thermostat housing and blocking it, which could cause over-heating issues.
Crossflow90
Oh boy, my response never seemed to have gone through but rather late than never.,thanks to rothfm and havoc_squad much appreciated
