1992 Force 90 Wiring Harness
Russdog
I am in the middle of a rebuild and need to replace the wiring harness. Can someone recommend where I can purchase wiring harnesses? What is the best way to identify the size/type needed?
jason32038
Re: 1992 Force 90 Wiring Harness
I dont know if you'll be able to find one of those. If you can't you can always go to the hardware store and get the wire and make your own. I'm sure you can find all the colors. You can have it cut to length then you go home and tape it up tight every foot then get some kind of heatshrink tubing to finish it off. Or you can run the wire through some type of heater hose but you'll have to seal up the ends with foam. I'm sure it will be way cheaper also!
jerryjerry05
E-bay or the dealer can get it for you.
I might have one.I'll look this morning.J
