1992 Johnson 200 cyl heads
houndawg
Anyone know how much the cyl heads on a<br />1992 johnson 200 can be cut? They are<br />casting #333809-4,just trying to up the<br />compression all cyl's but 1 has 85psi,<br />1 has 90psi.
rodbolt
Re: 1992 Johnson 200 cyl heads
cut about 1/2 inch off them and you will be fine.<br /> actually no.<br /> your numbers look good<br /> dont cut the heads thats about where the numbers are supposed to be. try decarbing once or twice and run carbon gaurd for a few tanks.
DHPMARINE
Well said rodbolt ! I actually limit it to 3/8 inch.<br />I wonder what the other 4 cylinders read?<br /><br />Let us know houndawg ! !<br /><br />DHP
houndawg
5 of the cyl's have 85psi, 1 cyl has 90 psi.<br />I would have figured this engine should have<br />around 100psi,i have been a auto technican for<br />16 years & dont have not owned a boat until<br />recently but these compression numbers just <br />seemed very low to me,just looked like there <br />is alot of room for improvement there.
DHPMARINE
houndawg,<br /><br />your readings are fine.I have never seen over 100 psi in these engines.It's the way they are.I think part of it is their slow cranking speed.<br />The good part is your readings are close to each other.<br />Do you have a specific problem with this motor?<br /><br />DHP
houndawg
Not really,just a speed freak i guess..I have a<br />22 pitch renegade on this motor on a 20 foot <br />stratos bass boat,the engine turns 6200 at wot<br />at 66.8 gps mph,was just trying to get to 70..<br />Thought if i could get more on the bottom to<br />get it on plane i could go to a 23 pitch prop<br />& hopefully see around 6000 & 70 mph.
rodbolt
hello<br /> there is a lot that can be done on that 200.repost and ask for Dhadley's attention. he seems to know a lot of speed tricks on the big loopers. I quit years ago. parts and diapers got to expensive :)
Dhadley
Actually youve got a great combo there. Good baseline info. The Renegades are pretty good props. There are some others to try in this area.<br /><br />Do you have a jackplate? If so, manual or hydraulic? Is the gearcase stock?
Dhadley
BTW -- the large exhaust port and port timing has a lot to do with the static compression numbers. As long as they're within 15 lbs youre good to go. Youre numbers are fine.
houndawg
That sounds good,just seemed low to me,boat has<br />a manual jackplate,I have played with heights but need to do some measureing to see how high its setting,water pressure gauge still not working correctly so I dont want to go too high,thinking<br />of trying the boyseen reeds also,I have tried a <br />renegade 23 & 25 pitch on this boat but had <br />weight locations,23 pitch at that time turned<br />around 6200 rpm but I didnt have gps at that time,<br />25 pitch turned around 5500 but only went 63mph on<br />gps,but I have moved most of the weight to the back of the boat since then & gained 2 mph with the same raker prop.
houndawg
I had meant to say I'm running a 22 raker,not a<br />renegade.
