1992 Stratos 2250 here we go again
ahmincha
These are the little bulkheads in between the stringers.nothing between the wood and hull and the wood is about 3/4" above hull just tabbed in P1010006_zps5e46ff8a.jpg
Woodonglass
My GUESS is they're there as stiffeners for the hull sides. But...That's JUST a guess. NO EXPERIENCE in that remark!!!!:nono:
kcassells
The gap may have been a "pre" type foam that deteriorated for one reason or another. All in all put the little piggies back better than they were. Cause thats what we do!
ahmincha
That is the plan kc And yes I believe you are right there is some foam here and there
ahmincha
So as I pulled the fiberglass off the stringers I found these strands in the plywood P1020002_zpsf6ef80f8.jpg P1020001_zps0acaccec.jpg
ahmincha
Pile of fiberglass
ahmincha
Some foam that was still attached to the bottom of the stringer This is all stringers and bulkheads striped from the fiberglass
Another pile of glassAnd finally the empty hull P1030001_zpsab81dc2e.jpg P1030002_zps0f69f9fd.jpg P1030003_zpsae0d67c5.jpg P1030004_zpsb7afcad4.jpg P1030005_zpsef24ad38.jpg
kcassells
"Some foam that was still attached to the bottom of the stringer "
Once and only once in-awhile I'm right! Most of the time I stand corrected!
ahmincha
This is a picture of how they joined the long stinger together P1030002_zps0f69f9fd.jpg
jc55
You really weighed it? That's great to know. Can you weigh your dry one before it goes in? Just under 8'...sweet!
