1992 yamaha 4 stroke 9.9 idle problem
nogimmies
Engine starts then runs ok for 30sec to 1 min then starts to sputter and dies.
Wait 2-3 minutes and restart with same thing happening
Cleaned carb checked jets and passages
checked filter ,fuel pump
when I loosen the Electo thermal valve runs for a little while longer and dies again
Thinking it may be the valve but reistance checks ok.
Puzzled on this one.
Click it into gear and rev for a while and runs ,but dies at idle.
CatTwentyTwo
Re: 1992 yamaha 4 stroke 9.9 idle problem
One other check for the thermal valve is to remove it from the motor and connect the leads to a 12 volt battery. The needle should extend as it warms up, this closes the cold start enrichment jet.
nogimmies
Needle did not move after on 12v for 3 minutes.
Checked again with meter and circuit is bad
Orderd a new electrothermal valve unit and some other parts.
Hopefully this will solve the problem.
Thanks for your input
nogimmies
nogimmies
Got it running without the ordered parts.
After all that fuss I found that the Air idle screw needed to be backed out another 1.5 turns to about 5.5 turns total vs 2-4 as manual calls for.
As soon as the thermovalve does its thing the engine would quit.
Not now
Engine runs like a Jap/swiss watch.
Now for my next endeavor
Changing the 9.9 to a 15 with some new jets.
I'll post my results.
nogimmies
