1989 17' Hoog flats boat with the 93 motor I picked it up from a local boat builder as a trade in. I had the fuel tank pumped out and cleaned before use. The dealer checked the compression, rebuilt the carbs and synchronized them,replaced the water pump and serviced the lower unit. THE MOTOR STARTS, IDLES, AND RUNS TO WOT WHEN COLD but when warm the motor still runs to wot, and will ilde slowly in gear, and neutral but will die when shifted into reverse from foreward as I approach the dock. I have the service manual. HELPPPPP
Thanking you in advance,
Mark
Mark
