HotTommy
- Mar 15, 2013
- 1,025
Some of you may remember the Force 150 I rebuilt last year. It's been doing well for a while except for those flywheel bolts that broke for no apparent reason a month ago. That problem was fixed and I've put about twenty hours on it since then. Today I encountered a new problem with three symptoms. I'll get out the FSM tomorrow and start troubleshooting it, but I'm interested in hearing where the old heads here think I should look first. Here are the high points.
It started easily cold and ran well for about three of my usual one hour use cycles. I usually tow kids on the tube for 15-20 minutes (80% to 100% throttle) before stopping to swim for 40-45 minutes. When I went to start the engine after a swim break, I noticed that the engine wanted to die as the throttle moved forward to engage the propeller. This was not normal. On the third attempt, I rapidly shoved the throttle forward and managed to keep the engine running at a fast idle. I pushed it up to pull the tube and everything seemed normal. But about 4-5 minutes later I felt the engine lose power as if I had pulled the throttle back. I pulled the throttle back to idle and the engine died. I shut off the key while I retrieved the people from the water. A few minutes later I turned on the key and heard what I believe was the overtemp horn. I did not restart the engine. I got a tow to the marina from a passing boater and have the boat and engine back home where I can work on it.
I suppose the impeller could have failed, but it is only one and a half seasons old. That and the fact that I did not enjoy reassembling the lower unit the last time I did that job makes me want to check other things first if they are likely or informative. So my question for the old guys is this. If this were you engine, where would you start to diagnose the problem?
