1993 force 90 OE016157 carb or elec problems
cripplecreek
I just replaced a bad stator last year before winterizing and boat ran fine at lost all speeds. this year took it out ran fine also for the first few times mostly at high rpms. After running at lower rpms it would bog out when getting t r's back up pulled the nkgBUHW plugs and they were fouled i replaced them with nkg BR8HS plugs because of suggestion from a friend running 50 to 1 ratio on inboard tank still same problem i then tried an external tank with 1 gallon 50 to 1 still same problem to rule out fuel contamination Im about ready to pull my hair out here any help or suggestions would be greatly appretiated..
